How to Use the SD Card with Raspberry Pi OS? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: How to Use the SD Card with Raspberry Pi OS? (/showthread.php?tid=3840) |
How to Use the SD Card with Raspberry Pi OS? - sysc - 12-12-2023 Hello, good morning/evening everyone, I've followed the instructions in this video to install the 64-bit Raspberry Pi OS on the eMMC. After inserting the SD Card, I checked the '/dev' folder and used the commands 'lsblk' and 'fdisk -l', but I couldn't find any trace of it. I tried with two different SD card models, both formatted in FAT32:
Am I forgetting something ? Thank you in advance! RE: How to Use the SD Card with Raspberry Pi OS? - admin - 12-12-2023 if your Pi is eMMC version, you can't use SD card. only can use eMMC. RE: How to Use the SD Card with Raspberry Pi OS? - sysc - 12-12-2023 Thanks for the response. Just to confirm, does this mean I can't use the SD card slot in the image I'm sharing? In this case, would I need to exchange the Raspberry Pi CM4 for another version that supports the use of the SD card slot? RE: How to Use the SD Card with Raspberry Pi OS? - admin - 12-12-2023 yes, you are right, because the default CM4 include eMMC. RE: How to Use the SD Card with Raspberry Pi OS? - admin - 12-20-2023 ??? |
