KCS Firmware multiple DS18B20 on the same GPIO - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: KCS Firmware multiple DS18B20 on the same GPIO (/showthread.php?tid=3878) |
KCS Firmware multiple DS18B20 on the same GPIO - tamibandy - 12-15-2023 Is there implemented to can read multiple DS18B20 temperature sensors on the same GPIO? If not, it is possible to implement some management for it by sensor's uniq id? Another question, is the KCS firmware open source? RE: KCS Firmware multiple DS18B20 on the same GPIO - admin - 12-15-2023 if you use arduino code or esphome, use same GPIO with multi DS18B20 sensor, no problem. But KCS not support multi ds18b20 with same GPIO, KCS firmware is not open source. RE: KCS Firmware multiple DS18B20 on the same GPIO - tamibandy - 12-15-2023 (12-15-2023, 10:56 AM)admin Wrote: if you use arduino code or esphome, use same GPIO with multi DS18B20 sensor, no problem. And are you planning to include that in the KCS firmware? RE: KCS Firmware multiple DS18B20 on the same GPIO - admin - 12-16-2023 sorry, no this plan. if you MUST want use multi ds18b20 with one GPIO. you can download ESPHome or Tasmota firwmare. |
