Turn Wi-Fi Off - Printable Version
+--- Thread: Turn Wi-Fi Off (/showthread.php?tid=388)
Turn Wi-Fi Off - basten - 08-06-2021
Is it possible to turn Wi-Fi completely off by any way (software or hardware)? I’d like to use my KC868-H32B controller in mqtt ethernet mode with radio module completely turned off.
RE: Turn Wi-Fi Off - admin - 08-06-2021
login with your wifi webpage, set work mode="STA", save and reboot. Then will not for use, until you do wifi reset.
another hardware way is short for wifi reset button two pin , wifi will down.
