Momentary Switch - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Momentary Switch (/showthread.php?tid=3935) |
Momentary Switch - anwar.sleem@gmail.com - 12-19-2023 I am looking for controlling two channel relays where it moves from NO to Closed and returns back to NO after 1 second. Which model is recommended and which protocol it supports? RE: Momentary Switch - admin - 12-19-2023 you can use KC868-A2 , it's ok for your requirements. support HTTP, MQTT, TCP command and Modbus protocol with RS485. RE: Momentary Switch - anwar.sleem@gmail.com - 12-20-2023 (12-19-2023, 06:46 AM)admin Wrote: you can use KC868-A2 , it's ok for your requirements. support HTTP, MQTT, TCP command and Modbus protocol with RS485.Does the time control will be in the code ? or on the module by default? RE: Momentary Switch - admin - 12-20-2023 if you download KCS firmware, it already have timer function. here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html |
