KC868-A16 Section Control AgIO v5.7 - Printable Version
+--- Forum: "KCS" firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40)
+--- Thread: KC868-A16 Section Control AgIO v5.7 (/showthread.php?tid=4021)
KC868-A16 Section Control AgIO v5.7 - zeltini1401 - 12-23-2023
You can help configure the KC868-A16 board so that the UDP AgIO v5.7 version program works when connected to a computer with a Lan cable, wifi or another way.
I want the output relays to respond to the section controller.
I don't understand much myself and I don't have any acquaintances who understand network settings very well.
RE: KC868-A16 Section Control AgIO v5.7 - admin - 12-24-2023
sorry, i don't understand the software. you can check whether the PC software support customsize protocol command. whether can define relay ON/OFF command by yourself.
RE: KC868-A16 Section Control AgIO v5.7 - zeltini1401 - 12-27-2023
Can you please check this code, is it correct? I loaded this sketch, the Lan port is no longer active.
RE: KC868-A16 Section Control AgIO v5.7 - admin - 12-28-2023
sorry, this need check by yourself.
RE: KC868-A16 Section Control AgIO v5.7 - zeltini1401 - 01-12-2024
Members of another forum corrected the section control files, now working.
Maybe there is a printable 3d box file for this A-16 board?
RE: KC868-A16 Section Control AgIO v5.7 - m_elias - 01-12-2024
(01-12-2024, 06:13 PM)zeltini1401 Wrote: Members of another forum corrected the section control files, now working.
Can you share the code?
RE: KC868-A16 Section Control AgIO v5.7 - zeltini1401 - 01-23-2024
The author will later post the code on Github.
RE: KC868-A16 Section Control AgIO v5.7 - m_elias - 01-23-2024
(01-23-2024, 03:15 PM)zeltini1401 Wrote: The author will later post the code on Github.
Please share the link when it's ready. Thank you!
