KC868-A32 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KC868-A32 (/showthread.php?tid=4035) |
KC868-A32 - Sunoc - 12-24-2023 Good morning ! I recently purchased the KC868-A32 card. My question is: can Kincony KCS and Home Assistant be used together? Thanks for your help. RE: KC868-A32 - admin - 12-25-2023 sure. you can download KCS firmware firstly , then integrate to home assistant by MQTT. RE: KC868-A32 - Sunoc - 12-25-2023 Thank you very much for your quick response RE: KC868-A32 - Sunoc - 12-29-2023 (12-25-2023, 12:08 AM)admin Wrote: sure. you can download KCS firmware firstly , then integrate to home assistant by MQTT. Good morning ! How to integrate MQTT into my Home Assistant? Do you have a step-by-step instruction manual? Thanks for your help RE: KC868-A32 - admin - 12-29-2023 this is sample config yaml: https://www.kincony.com/forum/showthread.php?tid=3274 RE: KC868-A32 - Sunoc - 12-29-2023 (12-29-2023, 12:13 PM)admin Wrote: this is sample config yaml: https://www.kincony.com/forum/showthread.php?tid=3274I have a KC868-A32 card. Do you have the yaml file? THANKS RE: KC868-A32 - admin - 12-29-2023 here is A32 integrate to home assistant by ESPHome's yaml: https://www.kincony.com/forum/showthread.php?tid=1772 we suggest use esphome directly, not need to use KCS. RE: KC868-A32 input - Sunoc - 05-04-2024 Hello ! With KC868-A32 I would like to invert the state of the inputs to be ok with the logic state in Home Assistant? THANKS RE: KC868-A32 - admin - 05-04-2024 if you config by ESPHome, just add "inverted" for INPUT option in yaml file. RE: KC868-A32 - Sunoc - 05-05-2024 (05-04-2024, 11:47 PM)admin Wrote: if you config by ESPHome, just add "inverted" for INPUT option in yaml file. Thank your very much |
