Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple (/showthread.php?tid=4080) |
Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - Tchip - 01-04-2024 Hi everybody! I'm new to the 7670C sim module and currently I still don't know how to configure it to receive, send messages and calls. I sent AT commands to it and it responded OK. But when I send messages and calls, it cannot make or receive calls and messages. Look forward to the help. Thank you so much! RE: Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - admin - 01-05-2024 do you have set the SMS service number firstly? you can insert your SIM card to your mobile phone have a test, whether can send SMS and make voice call. RE: Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - Tchip - 01-05-2024 (01-05-2024, 12:56 AM)admin Wrote: do you have set the SMS service number firstly? you can insert your SIM card to your mobile phone have a test, whether can send SMS and make voice call. Thank you for your early response. I have set the message center number and inserted the sim card completely. But it can't actually send or receive messages. I add that I have used this sim well with modules 800C and 900A. Code: AT+CPIN? Code: AT RE: Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - admin - 01-05-2024 check this sim card in your mobile phone. RE: Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - Tchip - 01-05-2024 (01-05-2024, 03:40 AM)admin Wrote: check this sim card in your mobile phone. I have tested all three sims and they all work fine on the mobile phone I am using. But when tested on SIM 7670C as mentioned above, one of them failed to work with messages and phone calls. The remaining 2 SIM cards respond OK to AT commands but they also have errors, one shows an error message: SIM not inserted. AT+CPIN? +CME ERROR: SIM not inserted And the third sim says busy. AT+CPIN? +CME ERROR: SIM busy I have tested a few sim 7670C modules but all have the same problem. Really don't understand what's going on? RE: Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - admin - 01-05-2024 check your power supply for SIM7670, it need large current when working. i have seen your photo, power supply by USB port, i think it's not enough for SIMCOM module. RE: Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple - Tchip - 01-06-2024 Thank you! I finally found it reason. |
