MQTT messages and IFTTT rules - yamaray - 01-08-2024
I like much your local implementation of IFTTT system, the interface is quite intuitive and fast to define a rule. Now I would like to involve into the IFTTT rules, some data coming or going out via MQTT protocol, so I am wondering if there is a way to involve MQTT messages into IFTTT conditions or/and actions.
In my opinion, it would be quite interesting to provide a way to send MQTT messages according to some conditions in the device or even take some internal actions according to a value from a specific received MQTT topic.
kind regards,
Yamaray
RE: MQTT messages and IFTTT rules - admin - 01-09-2024
sorry, MQTT not work with IFTTT command. i think you can use another way. you can config by ESPHome, it will support MQTT and IFTTT by your own setting.
RE: MQTT messages and IFTTT rules - a.demenev@limeup.ru - 02-03-2024
(01-09-2024, 12:39 AM)admin Wrote: sorry, MQTT not work with IFTTT command. i think you can use another way. you can config by ESPHome, it will support MQTT and IFTTT by your own setting.
Hi!
1) i have same task. Can you send some information how to do it?
2)I configure some IFTTT rules - it work fine, but i cant recieve\send any information via MQTT at all - i think instruction for MQTT connection is old - i have few errors in HA
i try this instruction: https://www.kincony.com/kc868-h32b-integrate-home-assistant-by-mqtt.html
but HA says some think like "this instruction was removed" for:
broker: 192.168.1.96
port: 1883
username: mqtt
password: 123
so my config is:
#=========KinCony A8 Ventilation=============
mqtt:
- name: 'A8_output-1'
unique_id: A8-output-1
state_topic: 'KC868_A8/B0A732862D60/state'
command_topic: 'KC868_A8/B0A732862D60/set'
state_on: 1
state_off: 0
- name: 'output-2'
unique_id: output-2
payload_on: '{"relay2":{"on":1}}'
payload_off: '{"relay2":{"on":0}}'
value_template: '{{ value_json.relay2.on }}'
state_on: 1
state_off: 0
#======== same for channel 3-8==============
- name: 'input-1'
unique_id: input-1
value_template: '{{ value_json.input1.on }}'
payload_on: 1
payload_off: 0
- name: 'input-2'
unique_id: input-2
value_template: '{{ value_json.input2.on }}'
payload_on: 1
payload_off: 0
#============same for channel 3-8==========
- name: 'A8_temp_ext'
unique_id: A8-temp-ext
value_template: '{{ value_json.sensor1.temperature }}'
- name: 'A8_temp_int'
unique_id: A8-temp-int
value_template: '{{ value_json.sensor2.temperature }}'
ATTENTION: "Part sensor:" i made myself, using MQTT Explorer, it may be incorrect
HA start correctly, but i have no any data
RE: MQTT messages and IFTTT rules - a.demenev@limeup.ru - 02-04-2024
(02-03-2024, 08:46 PM)a.demenev@limeup.ru Wrote: (01-09-2024, 12:39 AM)admin Wrote: sorry, MQTT not work with IFTTT command. i think you can use another way. you can config by ESPHome, it will support MQTT and IFTTT by your own setting.
Hi!
port: 1883
username: mqtt
password: 123
so my config is:
mqtt:
state_on: 1
state_off: 0
- name: 'output-2'
unique_id: output-2
state_on: 1
state_off: 0
- name: 'input-1'
unique_id: input-1
payload_on: 1
payload_off: 0
- name: 'input-2'
unique_id: input-2
payload_on: 1
payload_off: 0
Hi!
i fix this problem, this config is work fine:
Code: # KinCony A8 - Ventilation sysytem
mqtt:
- name: 'A8-output-1'
unique_id: a8_output_1
state_topic: 'KC868_A8/B0A732862D60/STATE'
command_topic: 'KC868_A8/B0A732862D60/SET'
payload_on: '{"output1":{"value":true}}'
payload_off: '{"output1":{"value":false}}'
state_on: true
state_off: false
- name: 'A8-output-2'
unique_id: a8_output_2
payload_on: '{"output2":{"value":true}}'
payload_off: '{"output2":{"value":false}}'
state_on: true
state_off: false
- name: 'A8-output-3'
unique_id: a8_output_3
payload_on: '{"output3":{"value":true}}'
payload_off: '{"output3":{"value":false}}'
value_template: '{{ value_json.output3.value }}'
state_on: true
state_off: false
- name: 'A8-output-4'
unique_id: a8_output_4
payload_on: '{"output4":{"value":true}}'
payload_off: '{"output4":{"value":false}}'
value_template: '{{ value_json.output4.value }}'
state_on: true
state_off: false
- name: 'A8-output-5'
unique_id: a8_output_5
payload_on: '{"output5":{"value":true}}'
payload_off: '{"output5":{"value":false}}'
value_template: '{{ value_json.output5.value }}'
state_on: true
state_off: false
- name: 'A8-output-6'
unique_id: a8_output_6
payload_on: '{"output6":{"value":true}}'
payload_off: '{"output6":{"value":false}}'
value_template: '{{ value_json.output6.value }}'
state_on: true
state_off: false
- name: 'A8-output-7'
unique_id: a8_output_7
payload_on: '{"output7":{"value":true}}'
payload_off: '{"output7":{"value":false}}'
value_template: '{{ value_json.output7.value }}'
state_on: true
state_off: false
- name: 'A8-output-8'
unique_id: a8_output_8
value_template: '{{ value_json.output8.value }}'
state_on: true
state_off: false
- name: 'A8-input-1'
unique_id: a8_input_1
payload_on: on
payload_off: off
- name: 'A8-input-2'
unique_id: a8_input_2
payload_on: on
payload_off: off
- name: 'A8-input-3'
unique_id: a8_input_3
value_template: '{{ value_json.input3.value }}'
payload_on: true
payload_off: false
- name: 'A8-input-4'
unique_id: a8_input_4
value_template: '{{ value_json.input4.value }}'
payload_on: true
payload_off: false
- name: 'A8-input-5'
unique_id: a8_input_5
value_template: '{{ value_json.input5.value }}'
payload_on: true
payload_off: false
- name: 'A8-input-6'
unique_id: a8_input_6
value_template: '{{ value_json.input6.value }}'
payload_on: true
payload_off: false
- name: 'A8-input-7'
unique_id: a8_input_7
value_template: '{{ value_json.input7.value }}'
payload_on: true
payload_off: false
- name: 'A8-input-8'
unique_id: a8_input_8
value_template: '{{ value_json.input8.value }}'
payload_on: true
payload_off: false
- name: 'A8-temp-ext'
unique_id: a8_temp_ext
value_template: '{{ value_json.sensor1.temperature }} '
unit_of_measurement: '°C'
- name: 'A8-temp-int'
unique_id: a8_temp_int
#==============END Kincony A8==========
RE: MQTT messages and IFTTT rules - admin - 02-04-2024
Yes, The new version of home assistant has changed its syntax.
(02-04-2024, 01:10 PM)admin Wrote: Yes, The new version of home assistant has changed its syntax.
Yes, that's what I thought.
I spent more than 10 hours to found solution - i am just a beginner user of Home Assistant and KinCony
Please, update your documentation - i think it will be usefull for other people
you can see this topic: https://www.kincony.com/forum/showthread.php?tid=1998
(02-04-2024, 01:39 PM)admin Wrote: you can see this topic: https://www.kincony.com/forum/showthread.php?tid=1998
Yes, i saw it, but syntax is different
that's was a problem
