Details for M30 board - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-M16 / M1 / MB / M30 (https://www.kincony.com/forum/forumdisplay.php?fid=50) +--- Thread: Details for M30 board (/showthread.php?tid=4185) |
Details for M30 board - nickdd - 01-22-2024 Hi, Would also be interested in new M30 board. But looking for some details: - What type of CT clamps are needed? The M16v2 works with SCT013 with 3.5 mm jack, but what type is needed here ? - Can you post details about the accuracy and especially if it can do stable readings of low power usage values like only a couple of watts. I would like to measure the real power usage of some electronic devices. - Does M30 measure active power, so taking into account the power factor / cos phi ? Regards, Nick cosϕ RE: Details for M30 board - admin - 01-22-2024 here is CT clamp for M30 board: https://es.aliexpress.com/item/3256805341385666.html just use output 0-1v or 0-50mA version of CT clamp sensor. RE: Details for M30 board - nickdd - 01-22-2024 (01-22-2024, 12:30 AM)admin Wrote: here is CT clamp for M30 board: https://es.aliexpress.com/item/3256805341385666.html ok but these are the same SCT013 clamps with 3.5 jack as with M16 board. On M30 picture I see terminals to screw them in. Do you need to cut off the 3.5 jack then? + any feedback on other question about accuracy and measuring active power? RE: Details for M30 board - admin - 01-22-2024 1. Yes, just cut the 3.5 jack, connect cable directly. 2. accuracy and measuring active power. accuracy is high. active power, voltage, current , frequency, power consume .etc. these data value read from BL0910 chip directly, it's calculated by hardware chip, here is video demo : https://youtu.be/y3AuMg6DdqQ RE: Details for M30 board - nickdd - 01-22-2024 (01-22-2024, 09:47 PM)admin Wrote: 1. Yes, just cut the 3.5 jack, connect cable directly. thanks, the video explained a lot. I would like to monitor power usage of electronics/computers/TV. With M16v2 that reports high power (50W for tv in standby where real power usage is 0.5W) Can you maybe post some results of measuring non-resistive loads like that? Would the 5A clamps be accurate enough to measure loads of 1-2 Watts ? No calibration needed with this M30 setup? RE: Details for M30 board - admin - 01-23-2024 Would the 5A clamps be accurate enough to measure loads of 1-2 Watts ? AC220v load 2W? it's too small for CT sensor. No calibration needed with this M30 setup? Yes, not need. RE: Details for M30 board - nickdd - 02-16-2024 (01-23-2024, 04:35 AM)admin Wrote: Would the 5A clamps be accurate enough to measure loads of 1-2 Watts ? AC220v load 2W? it's too small for CT sensor. I would like to see some real world measurements of small loads and know what levels of accuracy I could expect with this. My Zennio KNX KEsplus device states it has 8W resolution, which is indeed what I see in the results. And how come there is no calibration needed, it are the same clamps that are used then M16v2 |
