Scene controller switch - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Scene controller switch (/showthread.php?tid=4191) |
Scene controller switch - imoutofideas - 01-23-2024 Hi there. I'm really liking your products and i will be starting a large DIY project sometime in the future so i'm creating a list of products to use. One thing i can't find are wall scene switches that would work by connecting them to digital inputs using RJ45 cable. I know you offer some but i'm aiming at something more customizable like: https://buyriteelectric.com/cdn/shop/files/PJ2-4B-TSW-P11_1024x1024.jpg?v=1705342406 So multiple push buttons (no touch) that could send a signal to digital inputs. I'm from EU so i feel like my options are limited. I'm also open to suggestions if you know of another way to achieve this. Thank you! RE: Scene controller switch - admin - 01-24-2024 you can use our HAv2 RS485 adapter board, so that you can use any push button panel, work with KinCony's controller. here is video tour: https://youtu.be/s5Htc43HqAc RE: Scene controller switch - imoutofideas - 01-24-2024 I see, and if i wanted to connect multiple RS485 light/scene switches and/or motors which product could i use? For example if i were to buy and install (10+) of these switches which are using RS485: https://www.alibaba.com/product-detail/Modbus-rs485-switch-smart-room-programmable_1600303614145.html Which product can i use to read keypresses in home assistant and use that to control relays of H8B board for example? RE: Scene controller switch - admin - 01-24-2024 if you know the rs485 device protocol, usually use by modbus protocol, so you can use "modbus controller" in esphome to read it. RE: Scene controller switch - imoutofideas - 01-24-2024 But where would these switches connect to? Is there a Kincony board that has mutliple RS485 inputs? Or can i just connect to dry contact digital input ports? RE: Scene controller switch - admin - 01-24-2024 if you are using multi RS485 switch panel, you can parallel all RS485 cable with one bus. KinCony board's digital input ports support dry contactor devices. RE: Scene controller switch - imoutofideas - 01-25-2024 I see. Thank you! |
