Wall switch cabling and configuration - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Wall switch cabling and configuration (/showthread.php?tid=4198) |
Wall switch cabling and configuration - sebagarayco - 01-25-2024 Hi. I have a 6 gang wall switch connected to KC868-Server and the issue that I'm having is that when I connect Dx the LED is ON by default and when I turn on the relay the LED is OFF. Cabling: KCOM > GND K1 > Digital Input 1 DCOM > +12v D1 > Digital Output 1 I want LED to be ON when Relay 1 is ON... any ideas? RE: Wall switch cabling and configuration - admin - 01-26-2024 do you use home assistant software? or what software you are using? |
