LoraWan LMIC Solution (work with thethingsnetwork) - Printable Version
+--- Thread: LoraWan LMIC Solution (work with thethingsnetwork) (/showthread.php?tid=4216)
LoraWan LMIC Solution (work with thethingsnetwork) - sergalpe - 02-01-2024
Fix the card using pin 22 (nRF24L01 CE) and connect it with DI01 (view image)
Now the configuration in the project is as follows:
// Pin mapping
const lmic_pinmap lmic_pins = {
  .nss = 5,        // byte 0: pin for select
  .rxtx = LMIC_UNUSED_PIN,                                                               // byte 1: pin for rx/tx control
  .rst = 21,        // byte 2: pin for reset
  .dio = { /*dio0*/ 2, /*dio1*/ 22, /*dio2*/ LMIC_UNUSED_PIN },       // bytes 3..5: pins for DIO0, DOI1, DIO2
SPI.begin(18, 19, 23, 5);  // These specific pins are for kc868-a6
if (os_init_ex((const void *)&lmic_pins)) {
RE: LoraWan LMIC Solution (work with thethingsnetwork) - admin - 02-01-2024
thanks for share your job.
