A32 power trace thickness - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27) +--- Thread: A32 power trace thickness (/showthread.php?tid=4221) |
A32 power trace thickness - wsowa - 02-02-2024 Hi, what is the thickness of the traces between the load connector and the relay? Is the trace only on the bottom layer of the pcb or on bottom, top and inner layers (if there are any)? I'm trying to assess how much current the traces can actually handle. RE: A32 power trace thickness - admin - 02-03-2024 here is "bottom" and "top" PCB track length. |
