how to connect KC868 to home assistant - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Getting Started with ESPHome and Home Assistant (https://www.kincony.com/forum/forumdisplay.php?fid=54) +--- Thread: how to connect KC868 to home assistant (/showthread.php?tid=4225) |
how to connect KC868 to home assistant - eddiebullman - 02-03-2024 Ok I have my KV868-A6 & nRF24l01 boards how do I connect it to my wifi network and home assistant as I can't find anywhere how to connect every thing together I a completely new to once I get the thin connected I mite understand it better s RE: how to connect KC868 to home assistant - admin - 02-03-2024 do you want nRF24L01 work with home assistant? RE: how to connect KC868 to home assistant - Lucas35 - 02-22-2024 Connecting your KC868 to Home Assistant involves several steps. Here's a general guide, but keep in mind that specific details may vary based on your setup: 1.Connect KC868-A6 and nRF24l01 boards physically. 2.Configure KC868-A6 to connect to home Wi-Fi using a web interface or app. 3.Find the IP address of KC868-A6. 4.In Home Assistant's configuration file: switch: - platform: kc868 host: YOUR_KC868_IP_ADDRESS 5.Restart Home Assistant. 6.Check and test the KC868-A6 switch in Home Assistant interface Hope this helos, let me know how it goes RE: how to connect KC868 to home assistant - tamibandy - 03-26-2024 (02-22-2024, 11:50 AM)Lucas35 Wrote: Connecting your KC868 to Home Assistant involves several steps. Here's a general guide, but keep in mind that specific details may vary based on your setup: Can you explain a little bit more detailed this steps? I want to use KC868-A8. What firmware should I use for the controller? Thanks RE: how to connect KC868 to home assistant - admin - 03-27-2024 if you want use KC868-A8 integrate to home assistant, just use by ESPHome. you can download ESPHome config yaml file at here: https://www.kincony.com/forum/attachment.php?aid=1100 RE: how to connect KC868 to home assistant - jarekD - 06-16-2024 (03-26-2024, 06:04 PM)tamibandy Wrote:(02-22-2024, 11:50 AM)Lucas35 Wrote: Connecting your KC868 to Home Assistant involves several steps. Here's a general guide, but keep in mind that specific details may vary based on your setup: I also need more info, i.e. on the step " 2.Configure KC868-A6 to connect to home Wi-Fi using a web interface or app. " I just received my KC868-A16 and can't get started with it. After powering up for the first time, I can't see the WiFi network, nor it doesn't connect automatically to my LAN. How to connect to it to start configuring the device? RE: how to connect KC868 to home assistant - admin - 06-16-2024 if you want use A16 with home assistant, just use our ESPHome yaml file. if you want directly to use A16 board, you can download KCS firmware. note: when you download firmware, remove the RF 433M receiver module from PCB. RE: how to connect KC868 to home assistant - jarekD - 06-18-2024 (06-16-2024, 10:29 PM)admin Wrote: if you want use A16 with home assistant, just use our ESPHome yaml file. Can you please clarify, if I want to use A16 with Home Assistant and ESPHome, is this the yaml file to use? https://www.kincony.com/kc868-a16-ethernet-home-assistant-esphome-configure.html 1) The file is badly formatted. Is it available for download with proper formatting? 2) Can you explain where/how to add the file to home assistant installation? 3) Please clarify on the firmware: If I use this one: https://www.kincony.com/forum/showthread.php?tid=3791 Is this the valid firmware to have the A16 work with ESPHome in Home Assistant? When I go to ESPHome in Home assistant and click add device, it asks for IP and Port of the device. Should this work with A16? RE: how to connect KC868 to home assistant - admin - 06-19-2024 1. you can use this yaml file for A16 board: https://www.kincony.com/forum/showthread.php?tid=1628 2. install ESPHome add-on firstly on home assistant, then create device for A16, i think you can check this video tour: https://youtu.be/cEaZAF2YGCo 3. This is KCS firmware, if you want to use ESPHome, not use this one. just do as above video link, use by ESPHome is enough. |
