KC868-COLB Problem - Printable Version
+--- Thread: KC868-COLB Problem (/showthread.php?tid=4230)
KC868-COLB Problem - Faisal K - 02-04-2024
Hi for all
please help me :
I have KC868-COLB new one , i connect Ethernet Cable for first time and all Software are working find , then all RUN , Ethernet and WIFI Leds gowing Off and not working at allĀ
I tried to reset the Network Mode but still not working , only power and WIFI reset Leds On .
I Appreciation for answering .
RE: KC868-COLB Problem - admin - 02-04-2024
what you have done then can't work?
RE: KC868-COLB Problem - Faisal K - 02-05-2024
I bought a KC868-COLB device and when I received it I tried it and it worked well. I connected to it from the computer via Ethernet and via Wi-Fi and all the LEDs worked well and I could PING well.
But after two hours or more, only the POWER LED ON and no other work
I can no longer PING and all the remaining LEDs are no longer working
I Tried to reset Ethernet Mode and reset WIFI without any result , I Still Can't Ping and IP Scan also not find it.
please assist us to solve this Problem
note : i have not connect any device or any connection ecpect 12VPower Supply and Ethernet Cable .
RE: KC868-COLB Problem - admin - 02-06-2024
when you bought the COLB? can you take a CPU photo, i want to see chip model. (the biggest CHIP). i think need download firmware again.
RE: KC868-COLB Problem - Faisal K - 02-07-2024
(02-06-2024, 12:35 AM)admin Wrote: when you bought the COLB? can you take a CPU photo, i want to see chip model. (the biggest CHIP). i think need download firmware again.
Thanks , i Update the firmware Software and the Problem are solved .
Best Regards
RE: KC868-COLB Problem - admin - 02-08-2024
ok, good.
