Issue with KC868- server stuck - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: Issue with KC868- server stuck (/showthread.php?tid=4244) |
Issue with KC868- server stuck - sebagarayco - 02-07-2024 Hi, I’ve configured KC868-Server a few weeks ago in MQTT mode with Home Assistant. Suddenly I cannot access the admin console or power on the lights because of the ESP32 seems to be hung. Cannot access admin console or reset it manually by pressing the RESET ESP32 BUTTON. Board revision is 1.5 This is a real problem as I don’t know how to proceed in this case. Your help will be much appreciated Thanks RE: Issue with KC868- server stuck - admin - 02-07-2024 can't login home assistant webpage or KinCony's ethernet config webpage ? need details of your problem. RE: Issue with KC868- server stuck - sebagarayco - 02-07-2024 (02-07-2024, 07:10 AM)admin Wrote: can't login home assistant webpage or KinCony's ethernet config webpage ? need details of your problem. I can't login to KinCony ethernet config webpage. I can ping IP address but config webserver seems to be down. I can't change the network mode using the board buttons (S1, S2). I can't reset ESP32 config using reset button. It's completely stuck. This issue is not affecting Raspberry Pi as I'm able to connect to Home Assistant. Thank you RE: Issue with KC868- server stuck - admin - 02-07-2024 S1,S2 use for ESP32, config by yaml. you can use kincony scan device tool (https://www.kincony.com/download/UDP_SCAN_LIST.zip) to find out IP address, then use Chrome web browser to login . RE: Issue with KC868- server stuck - sebagarayco - 02-07-2024 (02-07-2024, 12:47 PM)admin Wrote: S1,S2 use for ESP32, config by yaml. Mistery solved. It was a networking issue related to DHCP lease which made the controller to go crazy. After fixing that everything is working again. Thanks. RE: Issue with KC868- server stuck - admin - 02-08-2024 ok, good. |
