Home assistant mqtt anolog sensor - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: Home assistant mqtt anolog sensor (/showthread.php?tid=4255) |
Home assistant mqtt anolog sensor - shuhrat - 02-08-2024 Hello the value sent via mqtt in home assistant does not change according to the template RE: Home assistant mqtt anolog sensor - admin - 02-08-2024 you can read analog input value from GPIO directly, not need use MQTT. just config yaml file for analog input. here is video tour about how to read analog port via ESPHome: https://www.kincony.com/forum/showthread.php?tid=3499 RE: Home assistant mqtt anolog sensor - shuhrat - 02-08-2024 I'm using kcs firmware. With esp home the controller freezes from time to time. Can you tell which kcs tamplate the analog sensor uses? I wanted to use this template in home assistant. RE: Home assistant mqtt anolog sensor - admin - 02-08-2024 post your config yaml file at here. RE: Home assistant mqtt anolog sensor - shuhrat - 02-09-2024 (02-08-2024, 11:12 PM)admin Wrote: post your config yaml file at here. esphome: name: kc868-a16s platform: ESP32 board: esp32dev # Enable logging logger: # Enable Home Assistant API api: encryption: key: "iJcfgpwJwZg9ObKzoD9XIa1KAQx8yAy7BZwuo3ye5cg=" ota: password: "f705fcd4ef788f830ac190213002873b" # Example configuration entry for ESP32 i2c: sda: 4 scl: 5 scan: true id: bus_a # Example configuration entry ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT phy_addr: 0 use_address: 192.168.30.110 # Example configuration entry pcf8574: - id: 'pcf8574_hub_out_1' # for output channel 1-8 address: 0x24 - id: 'pcf8574_hub_out_2' # for output channel 9-16 address: 0x25 - id: 'pcf8574_hub_in_1' # for input channel 1-8 address: 0x22 - id: 'pcf8574_hub_in_2' # for input channel 9-16 address: 0x23 # Individual outputs switch: - platform: gpio name: "a16s-output1" pin: pcf8574: pcf8574_hub_out_1 number: 0 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output2" pin: pcf8574: pcf8574_hub_out_1 number: 1 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output3" pin: pcf8574: pcf8574_hub_out_1 number: 2 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output4" pin: pcf8574: pcf8574_hub_out_1 number: 3 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output5" pin: pcf8574: pcf8574_hub_out_1 number: 4 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output6" id: switch_boiler_load pin: pcf8574: pcf8574_hub_out_1 number: 5 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output7" pin: pcf8574: pcf8574_hub_out_1 number: 6 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output8" pin: pcf8574: pcf8574_hub_out_1 number: 7 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output9" pin: pcf8574: pcf8574_hub_out_2 number: 0 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output10" pin: pcf8574: pcf8574_hub_out_2 number: 1 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output11" pin: pcf8574: pcf8574_hub_out_2 number: 2 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output12" pin: pcf8574: pcf8574_hub_out_2 number: 3 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output13" pin: pcf8574: pcf8574_hub_out_2 number: 4 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output14" pin: pcf8574: pcf8574_hub_out_2 number: 5 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output15" pin: pcf8574: pcf8574_hub_out_2 number: 6 mode: OUTPUT inverted: true - platform: gpio name: "a16s-output16" pin: pcf8574: pcf8574_hub_out_2 number: 7 mode: OUTPUT inverted: true binary_sensor: - platform: gpio name: "a16s-input1" pin: pcf8574: pcf8574_hub_in_1 number: 0 mode: INPUT inverted: true - platform: gpio name: "a16s-input2" pin: pcf8574: pcf8574_hub_in_1 number: 1 mode: INPUT inverted: true - platform: gpio name: "a16s-input3" pin: pcf8574: pcf8574_hub_in_1 number: 2 mode: INPUT inverted: true - platform: gpio name: "a16s-input4" pin: pcf8574: pcf8574_hub_in_1 number: 3 mode: INPUT inverted: true - platform: gpio name: "a16s-input5" pin: pcf8574: pcf8574_hub_in_1 number: 4 mode: INPUT inverted: true - platform: gpio name: "a16s-input6" pin: pcf8574: pcf8574_hub_in_1 number: 5 mode: INPUT inverted: true - platform: gpio name: "a16s-input7" pin: pcf8574: pcf8574_hub_in_1 number: 6 mode: INPUT inverted: true - platform: gpio name: "a16s-input8" pin: pcf8574: pcf8574_hub_in_1 number: 7 mode: INPUT inverted: true - platform: gpio name: "a16s-input9" pin: pcf8574: pcf8574_hub_in_2 number: 0 mode: INPUT inverted: true - platform: gpio name: "a16s-input10" pin: pcf8574: pcf8574_hub_in_2 number: 1 mode: INPUT inverted: true - platform: gpio name: "a16s-input11" pin: pcf8574: pcf8574_hub_in_2 number: 2 mode: INPUT inverted: true - platform: gpio name: "a16s-input12" pin: pcf8574: pcf8574_hub_in_2 number: 3 mode: INPUT inverted: true - platform: gpio name: "a16s-input13" pin: pcf8574: pcf8574_hub_in_2 number: 4 mode: INPUT inverted: true - platform: gpio name: "a16s-input14" pin: pcf8574: pcf8574_hub_in_2 number: 5 mode: INPUT inverted: true - platform: gpio name: "a16s-input15" pin: pcf8574: pcf8574_hub_in_2 number: 6 mode: INPUT inverted: true - platform: gpio name: "a16s-input16" pin: pcf8574: pcf8574_hub_in_2 number: 7 mode: INPUT inverted: true # Example configuration entry dallas: - pin: 14 update_interval: 5s # Individual sensors sensor: - platform: dallas address: 0x593c49f649496728 name: "temp hidrokollektora" - platform: dallas address: 0x82ae65841e64ff28 name: "temp boiler" id: temperature_boiler - platform: dallas address: 0xdd3ce5f649621628 name: "water temp" - platform: adc pin: A0 name: "Gaz Pressure" update_interval: 5s unit_of_measurement: "mbar" icon: "mdi:gauge" accuracy_decimals: 1 filters: - lambda: return (x-0.31)*160; - platform: adc pin: A6 name: "Water Pressure" update_interval: 5s unit_of_measurement: "Bar" icon: "mdi:gauge" accuracy_decimals: 3 filters: - lambda: return (x-0.31)*2.0696; RE: Home assistant mqtt anolog sensor - shuhrat - 02-09-2024 I use this code when I use esphome but the relay module freezes periodically every other day, at this time I turn off the power and turn it on and then it continues to work and after another day it freezes And I have to turn off the power again and that’s why I wanted to move to the kcs firmware. but with the kcs firmware it also froze yesterday, did not respond to the ip address, I rebooted the relay module RE: Home assistant mqtt anolog sensor - admin - 02-09-2024 which board model you are using? what power supply you are using? RE: Home assistant mqtt anolog sensor - shuhrat - 02-09-2024 KC868-A16S Mean well hdr-60 12v Can't connect to ESPHome API for kc868-a16s @ 192.168.30.85: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.30.85', port=6053))]: [Errno 113] Connect call failed ('192.168.30.85', 6053) (SocketAPIError) 12:04:08 – (ПРЕДУПРЕЖДЕНИЕ) runner.py kc868-a16s @ 192.168.30.85: Connection error occurred: Ping response not received after 90.0 seconds 12:04:07 – (ПРЕДУПРЕЖДЕНИЕ) runner.py there is this error in the logs RE: Home assistant mqtt anolog sensor - admin - 02-10-2024 i suggest you download KCS firmware for a testing whether work well. here is firmware download: https://www.kincony.com/forum/showthread.php?tid=3791 here is online guide for KCS firmware: https://www.kincony.com/guide |
