KC868-A8 PH and ORP sensor - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KC868-A8 PH and ORP sensor (/showthread.php?tid=4403) |
KC868-A8 PH and ORP sensor - eireit - 02-18-2024 Witch PH and chlorine sensor do you recommend for KC868-A8 (swimmingpool)? RE: KC868-A8 PH and ORP sensor - admin - 02-18-2024 you can use dc 0-5v output analog signal sensor. RE: KC868-A8 PH and ORP sensor - eireit - 02-19-2024 (02-18-2024, 10:49 PM)admin Wrote: you can use dc 0-5v output analog signal sensor. Thanks, for DI GPIO36/39, can these be used as counter to meassure flow 27 pulses per liter. How fastis this input? BR eirik RE: KC868-A8 PH and ORP sensor - admin - 02-19-2024 DI GPIO36/39 speed , you need confirm with ESP32 datasheet, you can try to test it. if only 27Hz, i think it will be ok. |
