Wall switch panel frame - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Wall switch panel frame (/showthread.php?tid=4693) |
Wall switch panel frame - v1rtus - 02-25-2024 Hello, I have ordered a wall switch panel recently, however the the metal frame size is 86mm x 86mm and in EU the frame size is 73mm x 73mm. It makes impossible to to put more that one switch next to each other. I added a photo of the EU electric round outlet boxes installed to a wall. Do you have EU size frames or e a 3d model of the metal frame, I would make it smaller and print it on a 3d printer? Thank you in advance! RE: Wall switch panel frame - admin - 02-25-2024 sorry, we not have EU panel, but you can order any EU switch panel (just "momentary" type , push button) can be used with KinCony's controller system. RE: Wall switch panel frame - v1rtus - 02-25-2024 unfrotunately there is very limited choice of momentatry switches and no alternatives for kincony ones. do you have a 3d model of the frame? I would modify it and 3d print it. I mean the frame on the photo: RE: Wall switch panel frame - admin - 02-25-2024 sorry,we not have the 3D file. |
