KC868-Hx Alexa change luminosity - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: KC868-Hx Alexa change luminosity (/showthread.php?tid=47) |
KC868-Hx Alexa change luminosity - elconfa - 11-21-2020 Hello, I bought the component to connect Alexa to my Home Domotic. Does it is possible to change the luminosity of the light? In Sinric or Alexa application I can change the luminosity, but from Alexa serial interface I read only RELAY-SET-255,2,1 (for ON) or RELAY-SET-255,2,0 (for OFF). The KC868-Hx Alexa Voice Module does not change the "value", for example from 255 to 125 for 50% of luminosity. How it is possible to send the "value" to the serial port? Thanks in advance Massimo RE: KC868-Hx Alexa change luminosity - admin - 11-22-2020 if you have use KC868-Hx relay controller, that's output for ON/OFF lamp. if you want to chagne brightness , you need use KC868-D8 controller, that's for dimmer, it support change brightness for lamp or LED strip. also we have open the voice module source code, you can download from our website: https://www.kincony.com/forum/showthread.php?tid=34 there are arduino code for Alexa and Google home speaker. if you have interesting you just change the output command for dimmer is ok. RE: KC868-Hx Alexa change luminosity - elconfa - 11-22-2020 (11-22-2020, 02:15 AM)admin Wrote: we have open the voice module source code, you can download from our website: https://www.kincony.com/forum/showthread.php?tid=34 Thanks for your answer. I noticed that the KC868-D8 controller does not have the RS232 port, but it would be a great upgrade to dimmer light using voice command. Can you help me to change the output command for dimmer? I need to send a serial command with the dimmer value. not only RELAY-SET-255,3,1 but also RELAY-SET-XXX,3,1 where XXX is the value from 0 to 255 or DIMMER-SEND-1,53 where 1 is channel-1,53 is the brightness for lamp Thanks for your help RE: KC868-Hx Alexa change luminosity - admin - 11-23-2020 KC868-D8 have RS485 port, you can use RS232-RS485 adapter, it can convert to RS232. |
