Library <Preferences.h> Not Storing Values - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4S (https://www.kincony.com/forum/forumdisplay.php?fid=41) +--- Thread: Library <Preferences.h> Not Storing Values (/showthread.php?tid=4769) |
Library <Preferences.h> Not Storing Values - job-systems - 03-01-2024 Hi, hope everyone is fine. I give up... I need help. I am unable to store values in non volatile memory, so that if there is a power loss, and re-power, the value keeps the same... example, a temperature setpoint. In my Arduino IDE environment I use: Node32s board (Is this the correct board? This is the configuration I have in Arduino IDE: GENERAL: #include <Preferences.h> Preferences preferences; // Start preferences service. SETUP: preferences.begin("almacenamiento-valores", false); // Start storage Serial.println("Escribiendo en NVS: 123"); preferences.putInt("offset", 123); // Write a test value of 123 on the memory space called "offset". int valorLeido = preferences.getInt("offset", 0); // Reads the stored value. Serial.print("Leído de NVS: "); Serial.println(valorLeido); // Show the value that was stored. preferences.end(); Result I get on serial monitor: Escribiendo en NVS: 123 Leído de NVS: 0 Result: Writing the value was not successful. What am I doing wrong? Would you advice using a different library for storing values? Maybe the board I have selected on Arduino IDE is the wrong one? Thank you for your help. BR, Juan |
