DC motor controller - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AM (https://www.kincony.com/forum/forumdisplay.php?fid=45) +--- Thread: DC motor controller (/showthread.php?tid=5275) |
DC motor controller - nickdd - 03-18-2024 Hi, Would this board be suitable to control a small DC motor (I want to automate the chicken coop door). Which motor controller would be suitable and can I just connect it to the GPIO pins in the green terminals? Can I also connect Hall effect sensor to detect open/closed state of the door? I believe ESP32 has built-in support for hall effect? sorry, still quite new to electronics/esp32 but therefore I'm looking at this nice board instead of starting from scratch. Appreciate the advice. Regards, Nick RE: DC motor controller - admin - 03-18-2024 what's your DC motor work voltage and current? RE: DC motor controller - nickdd - 03-19-2024 Hi, I still need to buy the components. Only need a very small motor to lift a 2 kg wooden door by rolling up a small string. So if there is advice on what to buy let me know. regards, Nick RE: DC motor controller - admin - 03-19-2024 you can chose any relay board, connect to your DC motor. |
