which board uses SX1278 LORA??? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: which board uses SX1278 LORA??? (/showthread.php?tid=5429) |
which board uses SX1278 LORA??? - masoos - 03-30-2024 Hi, which board you show in the picture for SX1278 Wireless Transceiver Module Lora 868Mhz? It has Lora and a small OLED display :-) I want this!!!! https://ae01.alicdn.com/kf/U580db2b9a8fb48728121c5e389638035x/SX1278-Wireless-Transceiver-Module-Lora-868Mhz-Long-Range-Wireless-Communication.jpg_80x80.jpg_.webp https://www.aliexpress.com/item/1005004209263611.html?spm=a2g0o.store_pc_allItems_or_groupList.0.0.1fb37222WXrm2F&pdp_npi=4%40dis%21EUR%21%E2%82%AC%204%2C52%21%E2%82%AC%204%2C52%21%21%214.76%214.76%21%402103847817118333415233885e9545%2112000028388718419%21sh%21DE%21802572425%21 RE: which board uses SX1278 LORA??? - admin - 03-30-2024 that use by KC868-A6: https://www.kincony.com/esp32-6-channel-relay-module-kc868-a6.html default LoRA SX1278 is 433MHz, if you want 868M, need conntact with aliexpress seller. |
