KC868-H32B and Smart Power distribution panel - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H32B and Smart Power distribution panel (/showthread.php?tid=5512) |
KC868-H32B and Smart Power distribution panel - fdcemb5 - 04-11-2024 We have noticed that KC868-H32B and Smart Power Distribution Panel do not show the IP addresses when scanned with Kincony Scanner. We have tried several routers, and the results are the same. When you connect only one to the router, the IP address will appear. The question is, since both cannot be connected at the same time to the same router, how do can we integrate them together. RE: KC868-H32B and Smart Power distribution panel - admin - 04-12-2024 take a photo how you connect all controller with your same router. all controller can connect to same router, maybe your controller use by STATIC ip, all are 192.168.1.200 so that have ip conflict. You'd better set your controller with DHCP mode, so set different static IP for different controller. |
