Calibration issue M16v2 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-M16 / M1 / MB / M30 (https://www.kincony.com/forum/forumdisplay.php?fid=50) +--- Thread: Calibration issue M16v2 (/showthread.php?tid=5590) |
Calibration issue M16v2 - RdP - 04-20-2024 Hi, I've been strugeling with a calibration issue. Code: [13:25:21][D][ct_clamp:041]: 'Measured Current-16' - Raw AC Value: 0.010A after 216 different samples (432 SPS)This is in the logging But I specified this in the yaml config Code: - platform: ct_clampA measured raw value of 0.010 should result in a 0.004 current value, but instead 0.13940 is the result. What am I doing wrong here? Thanks, Rien RE: Calibration issue M16v2 - admin - 04-20-2024 you can see this topic "AC voltage and calibration for M16": https://www.kincony.com/forum/showthread.php?tid=3764 RE: Calibration issue M16v2 - RdP - 04-20-2024 (04-20-2024, 12:02 PM)admin Wrote: you can see this topic "AC voltage and calibration for M16": https://www.kincony.com/forum/showthread.php?tid=3764 Hi I read that post already, but it's mainly about voltage calibration and I have an issue with current calibration. Which part of the mentioned post are you reffering to? Thanks, Rien RE: Calibration issue M16v2 - admin - 04-21-2024 what CT clamp type you are using? whether buy from KinCony? or yourself CT clamp sensor? |
