Issue with KC868-AIO-EXTAO--V1.2 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AIO (https://www.kincony.com/forum/forumdisplay.php?fid=46) +--- Thread: Issue with KC868-AIO-EXTAO--V1.2 (/showthread.php?tid=5591) |
Issue with KC868-AIO-EXTAO--V1.2 - mahafree - 04-20-2024 Hello, Since a few days I have been having problems with the analog outputs on my KC868-AIO. (KC868-AIO-EXTAO--V1.2) channels 1 to 6 work normally Channels 7 and 8 are off and no longer respond to anything. (the LEDs on the PCB are also off. With a voltmeter I measure 0V on the output) channel 9 works normally. Channels 10 and 11 are off and no longer respond to anything. (the LEDs on the PCB burn at 100%. With a voltmeter I measure 11.72V on the output) When other channels are at 100% I measure 10.2V on the output. channels 12 to 16 work normally. When I disconnect all outputs, the above remains the same. All other inputs and outputs work normally. I have no idea what happened. My configuration has not changed. All outputs are connected to the exact same type of dimmers. What else can I test? Is there something wrong with the "KC868-AIO-EXTAO--V1.2" board? Thank you in advance! RE: Issue with KC868-AIO-EXTAO--V1.2 - admin - 04-21-2024 you can test with KCS firmware, check these DAC ports whether work well. RE: Issue with KC868-AIO-EXTAO--V1.2 - mahafree - 04-21-2024 I installed the KCS software today to test with. The exact same problems. Channels 7 and 8 are "on" in the KCS software but the output stays low. Channels 10 and 11 are "off" in the KCS software but the output is 11.72V. RE: Issue with KC868-AIO-EXTAO--V1.2 - mahafree - 04-25-2024 What are the next steps i need to take? RE: Issue with KC868-AIO-EXTAO--V1.2 - admin - 04-25-2024 the AIO before is work well, no problem. after used some time, then begin this issue. or the first time use AIO, already have this issue? RE: Issue with KC868-AIO-EXTAO--V1.2 - mahafree - 04-26-2024 It's my first time using these channels. At first I only used the first 8 channels because I only had 8 dimmers. Channel 7 and 8 worked before. RE: Issue with KC868-AIO-EXTAO--V1.2 - admin - 04-26-2024 This is strange, if you use ESPHome and KCS firmware all have same problem. maybe the GREEN pcb have some problem. add whatsapp number: +86-15381188302 tell us your order number before, we re send you a new KC868-AIO board. RE: Issue with KC868-AIO-EXTAO--V1.2 - mahafree - 04-26-2024 Thank you very much! If you want, I can send the defective board to you for further investigation. RE: Issue with KC868-AIO-EXTAO--V1.2 - admin - 04-26-2024 the shipment fee will high, you don't need send back. RE: Issue with KC868-AIO-EXTAO--V1.2 - admin - 04-28-2024 today will re send you a new KC868-AIO controller. |
