No Response - Printable Version
+--- Thread: No Response (/showthread.php?tid=5653)
No Response - Vaughan2024 - 04-27-2024
I have a KC868-A16S with the following code on it , After installing it it now will not respond,
the relays will only activate via the on board push button not via home assistant interface?
Home assistant show the switch turn on but the board does nothing.
I there any suggestion why this is happing ?
Dose the code look ok and can I reset the board and reload the firmware.
  friendly_name: ESPHome IO Board
esp32:
  board: esp32dev
  framework:
    type: arduino
# Example configuration entry
ota:
  safe_mode: true
  password: !sectet ota_password
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.3
    gateway: 192.168.1.1
    subnet: 255.255.255.0
pcf8574:
    address: 0x24
  - id: 'pcf8574_hub_out_2' # for output channel 9-16
    address: 0x25
    address: 0x21
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      inverted: false
      number: 1
      mode: INPUT
      inverted: false
      number: 2
      mode: INPUT
      inverted: false
      number: 3
      mode: INPUT
      inverted: false
      number: 4
      mode: INPUT
      inverted: false
      number: 5
      mode: INPUT
      inverted: false
      number: 6
      mode: INPUT
      inverted: false
      number: 7
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_2
      number: 8
      mode: INPUT
      inverted: false
      number: 9
      mode: INPUT
      inverted: false
      number: 10
      mode: INPUT
      inverted: false
      number: 11
      mode: INPUT
      inverted: false
      number: 12
      mode: INPUT
      inverted: false
      number: 13
      mode: INPUT
      inverted: false
      number: 14
      mode: INPUT
      inverted: false
      number: 15
      mode: INPUT
      inverted: false
RE: No Response - admin - 04-28-2024
if you are using KC868-A16S, you can use this ESPHome config yaml file directly: https://www.kincony.com/forum/showthread.php?tid=2789
RE: No Response - Vaughan2024 - 04-28-2024
Thanks I found the problem after comparing to your code.
It was in the code, the numbers were out of order.
ok, good.
