KC868-A16S Analog input 4-20mA connection - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KC868-A16S Analog input 4-20mA connection (/showthread.php?tid=5713) |
KC868-A16S Analog input 4-20mA connection - nicolouts - 05-10-2024 Hello, I have a KC868-A16S device and I want connect 3 Analog sensor on it. My sensor provide a 4-20mA signal with 24VDC voltage. So I need to convert one of my signal to 0-5V with 250 ohms resistor and connect to CH1 or CH2 But I want to be sure, if I can connect directly my 4-20mA directly to CH3 and CH4 without damage the ADC of the ESP32. I know that maximum voltage for ESP32 ADC is 3.3VDC, is there a protecting circuit on KC868-A16S to prevent damage? What the purpose of LM224 on the drawing? Thank in advance. Regards Nicolouts RE: KC868-A16S Analog input 4-20mA connection - admin - 05-10-2024 use by 24V sensor is no problem, because work current also is 4-20mA. LM224 is an operational amplifier. RE: KC868-A16S Analog input 4-20mA connection - nicolouts - 05-10-2024 Hello, Thank you for your feedback. Do you have a wiring connection to be sure? My sensor is active, so it provide 24VDC to the current oop, can I connect GND together? Regards Nicolouts RE: KC868-A16S Analog input 4-20mA connection - admin - 05-10-2024 +24->your sensor power input, your sensor power output to KinCony's board's analog input port (current channel), analog input port --> your 24v power's GND. two power supply GND need connected together. RE: KC868-A16S Analog input 4-20mA connection - nicolouts - 05-14-2024 (05-10-2024, 10:49 PM)admin Wrote: +24->your sensor power input, your sensor power output to KinCony's board's analog input port (current channel), analog input port --> your 24v power's GND. two power supply GND need connected together. Hello, Thank you for your feeback. Regard Nicolouts |
