tuya adapter lost code - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: tuya adapter lost code (/showthread.php?tid=5726) |
tuya adapter lost code - Saif Kitany - 05-12-2024 i bought 2 new tuya adapter, first one, i puch the reset button and lost the code in esp chip. the second one, i tried to dowload the firmeware which support tcp connection, i did the steps as described in this linkĀ https://www.kincony.com/forum/showthread.php?tid=2339 but it didnt work. i tried to search the wifi of tuya by my laptob, and can't see it!!! RE: tuya adapter lost code - admin - 05-12-2024 which model you are using? do you use tuya adapter V2? V1 and V2 use by different firmware. what do you want to do with tuya adapter? work with which relay controller model? RE: tuya adapter lost code - Saif Kitany - 05-13-2024 I use Tuya adapter v1 work with H32B And another Tuya adapter v1 work with H32L RE: tuya adapter lost code - admin - 05-13-2024 here is firware for V1, you can download to use: https://www.kincony.com/forum/showthread.php?tid=2339 |
