how to install home assistant for Server-16 beginner guide - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53) +--- Thread: how to install home assistant for Server-16 beginner guide (/showthread.php?tid=5727) |
how to install home assistant for Server-16 beginner guide - admin - 05-13-2024 1. make home assistant SD card for KinCony Server-16. download https://www.raspberrypi.com/software/ 2. enable i2c for home assistant. Add files to enable I2C In the root of the hassos-boot partition, add a new folder called CONFIG. In the CONFIG folder, add another new folder called modules. Inside the modules folder add a text file called rpi-i2c.conf with the following content: i2c-dev In the root of the hassos-boot partition, edit the file called config.txt add two lines to it: dtparam=i2c_vc=on dtparam=i2c_arm=on 3. install HACS addon (use by SSH) https://hacs.xyz/docs/setup/download/ 4. MCP23008/MCP23017 implementation for Home Assistant (HA) https://github.com/jpcornil-git/HA-mcp23017 5. config yaml for MCP23017 install file edit add-on for HA , then config yaml https://www.kincony.com/forum/showthread.php?tid=5438 |
