Binary Inputs 9-15 turn off with 1-8 - Printable Version
+--- Thread: Binary Inputs 9-15 turn off with 1-8 (/showthread.php?tid=5754)
Binary Inputs 9-15 turn off with 1-8 - dockside - 05-16-2024
Used ESPHome to configure Digital Inputs. However both inputs 8 & 16 turn off when shorting input 16.  Same with inputs 9 & 15 when shorting input 15. Same with all inputs from 16 down to 9, that is inputs 8 down to 1 also turn off. My KC868-A16 board is at REV 1.6 and log information attached.
Thanks for the help.
Ted
RE: Binary Inputs 9-15 turn off with 1-8 - admin - 05-16-2024
take a photo how you wire your baord, we need see whole board and wire.
and upload your ymal file , not LOG file.
RE: Binary Inputs 9-15 turn off with 1-8 - dockside - 05-17-2024
I have no wires attached to the Digital inputs. I only have power connected; and communicate from Home Assistant using Wi-Fi. For testing I used a 1K resistor to short each input to GND.
(05-17-2024, 11:17 AM)dockside Wrote: I have no wires attached to the Digital inputs. I only have power connected; and communicate from Home Assistant using Wi-Fi. For testing I used a 1K resistor to short each input to GND.
Here's the yaml used:
friendly_name: KC868-A16-A
esp32:
board: esp32dev
framework:
type: arduino
sda: 4
scl: 5
# Example configuration entry
pcf8574:
- id: 'pcf8574_hub_out_1' # for output channel 1-8 address: 0x24
- id: 'pcf8574_hub_out_2' # for output channel 9-16 address: 0x25
- id: 'pcf8574_hub_in_1' # for input channel 1-8 address: 0x21
- id: 'pcf8574_hub_in_2' # for input channel 9-16 address: 0x22
# Digital outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
inverted: false
# Digital inputs
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      inverted: false
      number: 1
      mode: INPUT
      inverted: false
      number: 2
      mode: INPUT
      inverted: false
      number: 3
      mode: INPUT
      inverted: false
      number: 4
      mode: INPUT
      inverted: false
      number: 5
      mode: INPUT
      inverted: false
      number: 6
      mode: INPUT
      inverted: false
      number: 7
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      inverted: false
      number: 1
      mode: INPUT
      inverted: false
      number: 2
      mode: INPUT
      inverted: false
      number: 3
      mode: INPUT
      inverted: false
      number: 4
      mode: INPUT
      inverted: false
      number: 5
      mode: INPUT
      inverted: false
      number: 6
      mode: INPUT
      inverted: false
      number: 7
      mode: INPUT
      inverted: false
Looks like the address for the hubs need to be defined? Looks like the addresses ended up in the comments.
Ted
RE: Binary Inputs 9-15 turn off with 1-8 - admin - 05-17-2024
take a photo how you wire your baord, we need see whole board and wire. how many power supply you have used?
RE: Binary Inputs 9-15 turn off with 1-8 - dockside - 05-18-2024
I found the problem in the pcf8574: section of my YAML code. It's working now. Thanks.
RE: Binary Inputs 9-15 turn off with 1-8 - admin - 05-18-2024
ok, good
