Control fan speed using 0-10V and SSR - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AIO (https://www.kincony.com/forum/forumdisplay.php?fid=46) +--- Thread: Control fan speed using 0-10V and SSR (/showthread.php?tid=5756) |
Control fan speed using 0-10V and SSR - alankrit0113 - 05-17-2024 Hi, I am installing AIO in my house for complete control. Can I use 0-10v dimming channel with SSR to control speed of ceiling fan.? Also do I need a special SSR for that, commonly available SSR is “3-32V DC to 0-380V AC”. Will this type work or do I need some special SSR.? Thanks RE: Control fan speed using 0-10V and SSR - admin - 05-17-2024 yes, you need analog 0-10v SSR, here is order link: https://shop.kincony.com/products/analog-solid-state-relay-regulator RE: Control fan speed using 0-10V and SSR - alankrit0113 - 05-17-2024 Ok thanks a lot. RE: Control fan speed using 0-10V and SSR - alankrit0113 - 08-22-2024 Hi, I’ve already used the above suggested SSR to control fans, but it is not working as the fan is humming loud and does not spin at full brightness (i.e 10V input). How can I control it please suggest. I’ve done wiring as per your advised diagram. RE: Control fan speed using 0-10V and SSR - admin - 08-22-2024 take a video of your problem, send to whatsapp number: +86-15381188302 |
