KC868-A8 - Possible to use A1 and A2 as standard inputs? - Printable Version
+--- Thread: KC868-A8 - Possible to use A1 and A2 as standard inputs? (/showthread.php?tid=5780)
KC868-A8 - Possible to use A1 and A2 as standard inputs? - deanfourie - 05-21-2024
I have used up all the inputs on my KC868-A8,
Is it possible to use A1 and A2 as standard inputs using NO/NC contacts.
Thanks
RE: KC868-A8 - Possible to use A1 and A2 as standard inputs? - admin - 05-21-2024
do you want use dry contact signal for analog input port, no voltage?
