Update via Ethernet with OTA - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Update via Ethernet with OTA (/showthread.php?tid=5868) |
Update via Ethernet with OTA - Brouk - 06-12-2024 In the specification https://esphome.io/components/ota.html it is stated "In that mode, all components are disabled and only Serial Logging + Network(WiFi or Ethernet) + OTA are initialized, so that you can upload a new binary ." I have an A16 integrated with HomeAssistant. In ESPHome new version of YAML can be downloaded to the A16 without any problems via USB cable. Update via Ethernet cable (same network, WiFi not available) ends with an error. Is it possible to install the update via Ethernet? Please could you send me the OTA code for the YAML file of the A16 device? RE: Update via Ethernet with OTA - admin - 06-12-2024 OTA means (Over The Air) . use by wifi. here is details: https://esphome.io/components/ota.html for example, if you create a new board "aaa" in ESPHome, that default enabled OTA: esphome: name: aaa friendly_name: aaa esp32: board: esp32dev framework: type: arduino # Enable logging logger: # Enable Home Assistant API api: encryption: key: "BuaN05EoLtK4ZR+FNhlQmAGVSk7omzGlcjEEtbgZst8=" ota: password: "2be8fee6977896009887933fa3b89529" wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: "Aaa Fallback Hotspot" password: "yz1B8CHcDdWd" captive_portal: |
