KC868-A2 with ESP32 Cam - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A2 (https://www.kincony.com/forum/forumdisplay.php?fid=43) +--- Thread: KC868-A2 with ESP32 Cam (/showthread.php?tid=5878) |
KC868-A2 with ESP32 Cam - taalaibek - 06-13-2024 I tried connect ESP32 Cam to KC868-A2 via I2C but doesn't work, can you help me please? SDA (GPIO4) on the Kincony board to SDA (GPIO14) on the ESP32-CAM. SCL (GPIO16) on the Kincony board to SCL (GPIO15) on the ESP32-CAM. GND on the Kincony board to GND on the ESP32-CAM. 3.3V on the Kincony board to 3.3V on the ESP32-CAM. initialization in mycropython: i2c =machine.I2C(0, scl=machine.Pin(16), sda=machine.Pin(4)) RE: KC868-A2 with ESP32 Cam - admin - 06-13-2024 i am not used with ESP32 cam. i think you can check your software code. the hardware interface only 4 cables. just the cable can't too long, <50cm is better. RE: KC868-A2 with ESP32 Cam - taalaibek - 06-14-2024 (06-13-2024, 01:00 PM)admin Wrote: i am not used with ESP32 cam. i think you can check your software code. the hardware interface only 4 cables. just the cable can't too long, <50cm is better. cable is not too long just 20cm i2c =machine.I2C(0, scl=machine.Pin(16), sda=machine.Pin(4)) is it correct or not? RE: KC868-A2 with ESP32 Cam - admin - 06-14-2024 IIC BUS of KC868-A2: SDA:4 SCL:16 |
