KCS Firmware and home assistant together ? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" v2 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: KCS Firmware and home assistant together ? (/showthread.php?tid=5963) |
KCS Firmware and home assistant together ? - Kais - 06-24-2024 Hello ! Is there a way to run KCS Firmware and home assistant simultaneously? RE: KCS Firmware and home assistant together ? - admin - 06-25-2024 sure, download KCS firmware to ESP32, then use MQTT integrate to home assistant. RE: KCS Firmware and home assistant together ? - Kais - 06-25-2024 Well that's a solution but unfortunately not what i'm looking for. For my use case I have an A32 board pro with integrated Sim module, I want to access and use that SIM module as action trigger when sms recived from home assistant. to you have any idea how to get access and use that sim module directly from HA ? have a nice day
RE: KCS Firmware and home assistant together ? - admin - 06-25-2024 maybe you can try this: https://github.com/esphome/feature-requests/issues/1810 RE: KCS Firmware and home assistant together ? - Kais - 06-26-2024 Thank you i'll give you a try, Last question : do you have a ready yaml file fo HA MQTT integration to A32 board ? RE: KCS Firmware and home assistant together ? - admin - 06-26-2024 you can see this, this for A8S board : https://www.kincony.com/forum/showthread.php?tid=3274 but it's as same as A32's yaml. |
