which board and button - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: which board and button (/showthread.php?tid=6016) |
which board and button - Silver - 07-03-2024 Translator Hello, I would like to know whether the following project is possible and what people think about what I need to order: I would like to control a rain sprinkler system via home assistant. I think I need a board that is controlled with Ethernet and can control 4-6 relays 24 volt "Hunter 24vac valves (magent coil)". I would like to have an optional switch, for example hhttps://shop.kincony.com/products/touch-switch-panel-dry-contact-signal?variant=43573355511973 or hhttps://shop.kincony.com/products/8-gang-wall-toggle-reset-switch-push-button-momentary-contact-for-smart-home-automation-diy If necessary, you can control the release without a home assistant or an app. Thank you Dennis RE: which board and button - admin - 07-03-2024 yes, you can use either one connect to KinCony relay board's digital input ports. |
