KC868-D16 - what's the max load(s)? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-D16 - what's the max load(s)? (/showthread.php?tid=6018) |
KC868-D16 - what's the max load(s)? - andy - 07-03-2024 Hi, Some questions about KC868-D16. First one - what is the maximum load [Watt] per channel and max summary for module? Second one - what's the dimming type? Phase-cut dimming, Pulse Width Modulation, Resistance dimming or some else? And additional little out of topic - can this module work directly with Tuya, without any additional Kincony's controller/gateway/etc? Regards. RE: KC868-D16 - what's the max load(s)? - admin - 07-03-2024 1: KC868-D16 not drive load directly, it need add dc 0-10v driver for DC12v/24V LED strip. so the MAX load [Watt] according to the "driver". 2. KC868-D16 is output dc 0-10v voltage signal. 3. sure, KC868-D16 is a tuya dimmer controller, use tuya app directly without other gateway. RE: KC868-D16 - what's the max load(s)? - andy - 07-04-2024 (07-03-2024, 11:57 PM)admin Wrote: 1: KC868-D16 not drive load directly, it need add dc 0-10v driver for DC12v/24V LED strip. so the MAX load [Watt] according to the "driver". Thank you for quick reply. So, that module cannot control dimmable 230V LED bulbs directly itself? Is there any other multi-channel module which can do that? RE: KC868-D16 - what's the max load(s)? - admin - 07-04-2024 So, that module cannot control dimmable 230V LED bulbs directly itself? Yes, but add analog SSR is ok, then KC868-D16 can control AC220V lamp. here is link: https://shop.kincony.com/products/analog-solid-state-relay-regulator because the SSR control AC 0-220v output by analog input DC 0-10V |
