Automation for my new apartment - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Automation for my new apartment (/showthread.php?tid=6068) |
Automation for my new apartment - drazvan2003 - 07-14-2024 Hello Kincony, I have been watching for some time your channel and really love what you did with the distribution box. I would like your opinion on what's the best approach regarding automation for the following setup: 1 kitchen circuit for 32 amps 11 outlets (16 amp circuit) 16 lightbulbs (10 amp circuits) 12 light switches 4 motion sensors 4 temperature sensors I was looking at this distribution box - https://shop.kincony.com/products/16ch-raspberry-pi-distribution-panel-home-assistant-node-red but i'm not entirely sure if it covers all my needs Im planning to use this with home assistant and use alexa for voice command, and in the future i might install 5 automatic window blinds Best regards RE: Automation for my new apartment - admin - 07-15-2024 this DB version also is OK, just it need you config by Node-Red for alexa and google home speaker. if you chose the new controller version, so that you can use alexa and google home speaker directly, because that will support tuya app. here is new 32CH DB version, if you only want 16 channel, we can also make for 16 channel. https://www.kincony.com/smart-distribution-panel-tuya-home-assistant-homekit.html RE: Automation for my new apartment - drazvan2003 - 07-16-2024 thanks a lot for the info. is there any video on your channel that explains the schematics ? for example from circuit braker (live wire 1 to 16) you have a wire that goes into the contactors(live wire 1) and from other circuit breaker it goes into the extension relays (live wire 17 to 32) https://www.kincony.com/forum/attachment.php?aid=1912 best regards RE: Automation for my new apartment - admin - 07-16-2024 this is video about 24CH, you can see here: https://youtu.be/FE5fSduc0uI also you can see the newest solution video tour: https://youtu.be/VWdgOWRFN4I explain hardware details: https://youtu.be/U8B4DW1U940 RE: Automation for my new apartment - Wonders - 07-22-2024 Pls sir, do you have a video on how to config the old DB version using Node-Red? RE: Automation for my new apartment - admin - 07-22-2024 what's means "old DB version"? RE: Automation for my new apartment - drazvan2003 - 07-25-2024 i saw in one of the videos - https://youtu.be/nFu80X-f-XY?si=e7pyXjuc3_DDjcLu&t=218 that there is a small pcb board that needs to be attached to the light switch. From what i understand this converts the light switch into a smart one that sends signal to the server and the server will trigger the relay to perform the action. Is that correct ? And where can i find to buy that pcb ? RE: Automation for my new apartment - admin - 07-25-2024 yse, the adapter let your switch connect to relay controller by RS485. here is V2 version order link: https://shop.kincony.com/products/kc868-hav2-rs485-io-module RE: Automation for my new apartment - drazvan2003 - 07-25-2024 does it comes with that pin connectors, or do i need to get them separately and where ? thanks RE: Automation for my new apartment - admin - 07-25-2024 will include the connectors. |
