Server 16 internal Relays - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53) +--- Thread: Server 16 internal Relays (/showthread.php?tid=6360) |
Server 16 internal Relays - sebagarayco - 08-12-2024 Hi Kincony, I know for sure that my load will be below 7 AMPS per channel. Same happens for a H32B-Pro that I have. Do I need anyway KC868-E16v2 ? It would be better not to use internal 7 amp relays of the Server 16 / H32B-Pro? Please elaborate so I can size my distribution box properly. Thanks RE: Server 16 internal Relays - admin - 08-12-2024 Yes, use exend relay module KC868-E16v2 is best way. Server16 inside relay MAX is 7A, for safety , your load current should <3.5A. |
