DS18B20 issues with KC868-Server - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: DS18B20 issues with KC868-Server (/showthread.php?tid=6427) |
DS18B20 issues with KC868-Server - sebagarayco - 08-16-2024 Hi, I'm having issues with multiple DS18b20 sensors connected to KC868-Server. I only receive temperature from one sensor and have two connected. The sensor that is working is connected to GPIO4 and the one that is not working is connected to GPIO1 (yellow cable) This is my config: one_wire: - platform: gpio id: pin4 pin: 4 - platform: gpio id: pin1 pin: 1 sensor: - platform: dallas_temp one_wire_id: pin4 address: 0x880b232213a28e28 name: "Board Temperature" I'm expecting to see the ID of the sensor connected to GPIO1 , instead I'm getting FOUND NO DEVICES ( already tried different GPIO port, same result) RE: DS18B20 issues with KC868-Server - admin - 08-17-2024 take a photo , how you wire, you can also use multi ds18b20 with one GPIO, it's easier. RE: DS18B20 issues with KC868-Server - sebagarayco - 08-17-2024 (08-17-2024, 01:44 AM)admin Wrote: take a photo , how you wire, you can also use multi ds18b20 with one GPIO, it's easier. If wire two Yellow to same GPIO how to differentiate in the code (home assistant)? RE: DS18B20 issues with KC868-Server - admin - 08-17-2024 every DS18B20 have different address. it will auto scanned in LOG. you just connect together, see the ESPHome LOG will found all DS18B20. RE: DS18B20 issues with KC868-Server - sebagarayco - 08-17-2024 (08-17-2024, 02:22 AM)admin Wrote: every DS18B20 have different address. it will auto scanned in LOG. you just connect together, see the ESPHome LOG will found all DS18B20. Ok. Will try it but want to know why other GPIOs are not working… what could be the issue? Bad sensor? RE: DS18B20 issues with KC868-Server - admin - 08-17-2024 i have said: take a photo how you wire. RE: DS18B20 issues with KC868-Server - sebagarayco - 08-17-2024 (08-17-2024, 05:27 AM)admin Wrote: i have said: take a photo how you wire. RE: DS18B20 issues with KC868-Server - admin - 08-18-2024 these 4 pins are: GPIO19,GPIO18,GPIO5,GPIO4 do you have define correctly? these are actually GPIO number for ESP32 module. RE: DS18B20 issues with KC868-Server - sebagarayco - 08-20-2024 (08-18-2024, 12:09 AM)admin Wrote: these 4 pins are: You are right sir. I was using GPIO1, 2, 3 and 4. That's why only 4 worked. Thanks for your help RE: DS18B20 issues with KC868-Server - admin - 08-20-2024 ok, good. |
