KC868-A16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: KC868-A16 (/showthread.php?tid=6443) |
KC868-A16 - vjh - 08-18-2024 Good morning, ESP32 works limitedly in AP mode, LAN does not work even as a static address, can be connected via wifi. As soon as you enter the transition to STA mode the ESP32 stops working (other ESP32 in the same place works without problems) (it does not get an address, the DHCP server does not have a new client). According to the log from the serial port, as soon as you enter transition to STA mode, the listing ends. I tried using firmware V2.2.2. RE: KC868-A16 - admin - 08-18-2024 which board you are using? KC868-A16? what problem with you? can you take a video? now i don't understand your problem. |
