A32Pro problem whit lan and ntp - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: A32Pro problem whit lan and ntp (/showthread.php?tid=6446) |
A32Pro problem whit lan and ntp - Carlithost - 08-19-2024 Good morning, I have a KinCony A32 Pro 32 module, firmware version 1.0.5 and I noticed these anomalies: 1. the time zone does not update, I tried to enter various ntp servers but to get the correct time for my zone (UTC+1) I have to enter UTC+8. 2. if I set the LAN IP in DHCP everything works fine, if instead I set it in static, the module blocks as if it were in conflict with another IP address. By removing the network cable it starts working again but logically without lan but only in wifi. Thanks for help. RE: A32Pro problem whit lan and ntp - admin - 08-19-2024 1. we will feedback to our software team. 2. do you means can't work with STATIC by ethernet? RE: A32Pro problem whit lan and ntp - Carlithost - 08-19-2024 (08-19-2024, 11:59 AM)admin Wrote: 1. we will feedback to our software team. Thanks for the reply, yes, if I set static IP the card freezes, the display shows the last screen before the restart sometimes with an interference of lit pixels then it always turns off and on again with the same image, the LEDs of the Ethernet adapter flash a few times then they go off for a few seconds then flash again, as if it were continually restarting without being able to set the ethernet adapter. to make the system work again I have to disconnect the LAN cable and work in wifi to set again in dhcp and everything works again. These are the parameters I set in static (image) show display when static ip is on RE: A32Pro problem whit lan and ntp - admin - 08-19-2024 can you take a video of your all step. i will do as your video. you can send video to whatsapp number: +86-15381188302 or you can upload to Google driver. |
