I Need Help Kincony KC868-A8 Integration - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: I Need Help Kincony KC868-A8 Integration (/showthread.php?tid=6479) |
I Need Help Kincony KC868-A8 Integration - henryclark - 08-26-2024 Hello all, I am working on a project that requires integrating Kincony's KC868-A8 relay controller into a custom automation system, and facing some challenges related to communication protocols, data handling, and device reliability;
I am eager to learn from the community's collective knowledge and experience. Any insights or suggestions would be greatly appreciated... Thanks in advance for my help.... RE: I Need Help Kincony KC868-A8 Integration - admin - 08-26-2024 KC868-A8 support HTTP, MQTT, TCP command protocol. you can chose protocol for integration according to your system structure. we don't have SDK, but just check with protocol document is enough. here is KCS firmware for HTTP, MQTT, TCP protocol documents download: https://www.kincony.com/forum/forumdisplay.php?fid=40 RE: I Need Help Kincony KC868-A8 Integration - henryclark - 08-26-2024 (08-26-2024, 06:08 AM)admin Wrote: KC868-A8 support HTTP, MQTT, TCP command protocol. you can chose protocol for integration according to your system structure. I will check it out, thanks for sharing this guideince.... RE: I Need Help Kincony KC868-A8 Integration - admin - 08-26-2024 you are welcome. |
