PZEM-004T With A6 on Serial - Printable Version
+--- Thread: PZEM-004T With A6 on Serial (/showthread.php?tid=6568)
PZEM-004T With A6 on Serial - Techno - 09-02-2024
Howdy!
Thanks for the A6 Board, im using the second one already and i enjoy it.
I encountered a problem, connected PZEM-004T to Serial on A6 (GPIO12, 13)
When i power the board, it doesnt boot. I plug out the PZEM-004T from A6, it boots. I plug pzem back in. It works normaly, and i receive all the needed data.
What is the problem i have on boot?
pastebin code:
https://pastebin.com/Rbujh2R1
code:
friendly_name: KotelA6
libraries:
- "Wire"
- "ArduinoJson"
esp32:
board: esp32dev
framework:
type: arduino
wifi:
ssid: !secret wifi_ssid
encryption:
key:
captive_portal:
ota:
password: "
uart:
- id: ubus1
tx_pin: GPIO13
rx_pin: GPIO12
baud_rate: 9600
stop_bits: 1
sda: GPIO4
scl: GPIO15 # Change SCL to GPIO22 to avoid issues with GPIO15
pcf8574:
address: 0x24
- id: 'pcf8574_hub_in_1' # for input channel 9-16
address: 0x22
pcf8575: false
time:
- platform: ds1307
#### PZEM-004T V3 ####
- platform: pzemac
address: 1
current:
accuracy_decimals: 2
voltage:
power:
unit_of_measurement: W
frequency:
unit_of_measurement: Hz
power_factor:
energy:
unit_of_measurement: Wh
accuracy_decimals: 1
update_interval: 5s
- platform: template
unit_of_measurement: "kWh"
update_interval: 5s
icon: mdi:power
lambda: return (( (id(pMeter_energy).state)/1000.0));
- platform: total_daily_energy
power_id: pMeter_power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
icon: mdi:counter
unit_of_measurement: "kwh"
icon: mdi:power
update_interval: 10s
unit_of_measurement: "VA"
icon: mdi:power
lambda: return ( (id(pMeter_power).state/id(pMeter_power_factor).state));
unit_of_measurement: "VAr"
icon: mdi:power
lambda: return ( ( sqrt( (id(pMeter_power_apparente).state)*(id(pMeter_power_apparente).state) - (id(pMeter_power).state)*(id(pMeter_power).state) ) ) );
- platform: wifi_signal
name: "WiFi power_pMeter"
- platform: uptime
text_sensor:
lambda: |-
int seconds = (id(uptime_sec).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
icon: mdi:clock-start
update_interval: 113s
################################################# SENSOR
- platform: status
icon: mdi:home-flood
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
################################################# RELAYS
- platform: restart
### KINCONY 1
icon: mdi:fan
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
########################### ######### BOILER PUMP
icon: mdi:pump
number: 2
mode: OUTPUT
################################## #RECIRCULATE
icon: mdi:pump
number: 3
mode: OUTPUT
######################## INTERLOCK WATER STOP ###########################
icon: mdi:water-off-outline
number: 4
mode: OUTPUT
interlock: [relay_6] # Interlock with Grow Pump_6
icon: mdi:water
number: 5
mode: OUTPUT
interlock: [relay_5]
restore_mode: ALWAYS_ON
RE: PZEM-004T With A6 on Serial - mikesloper - 09-02-2024
Lol, just came here to ask the same question. I'm trying to add a second RS485 module using GPIO12 and GPIO13.
Also doesn't boot and I get the following serial output:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x37 (SPI_FAST_FLASH_BOOT)
invalid header: 0xffffffff
RE: PZEM-004T With A6 on Serial - Techno - 09-02-2024
I made a workaround hack, it is dumb but it works.
Used one of the relays in NO to break GPIO12. and on boot made a sequence so that it switches on (GPIO12 starts working after board has booted)
It ate one of the relay on board, i will wait for the admin for any advice
  on_boot:
    priority: 600  # Boot priority, ensure it happens after most components have started
    then:
      - delay: 10s
      - switch.turn_on: relay_3
RE: PZEM-004T With A6 on Serial - admin - 09-03-2024
GPIO12 use for ESP32 start.
KC868-A6 have two GREEN terminal free GPIO (label: GPIO-1, GPIO-2) they are GPIO32,GPIO33. So you can use these pins for your serial port device.
here is schematic for KC868-A6: https://www.kincony.com/download/KC868-A6-schematic.pdf
RE: PZEM-004T With A6 on Serial - mikesloper - 09-03-2024
(09-03-2024, 06:13 AM)admin Wrote: GPIO12 use for ESP32 start.
Do you mean  TEM./HUMI./1# and  TEM./HUMI./2# terminals can be used for serial?
  on_boot:
    then:
      - delay: 10s
I like that, unfortunately all my relays are used.
I think I have no choice but to use a UART to I2C bridge. see https://esphome.io/components/weikai.html
RE: PZEM-004T With A6 on Serial - Techno - 09-03-2024
you mean these?
yes, you are right. TEM./HUMI./1# and TEM./HUMI./2
RE: PZEM-004T With A6 on Serial - Techno - 09-12-2024
(09-03-2024, 11:47 PM)admin Wrote: yes, you are right. TEM./HUMI./1# and  TEM./HUMI./2
I got in to question
Right now i have ports:
  • Temp1 for temp sensors (Pin Temp1)
  • Temp2 for Pzem (PIN 13 and Pin Temp2)
all is working great.
I want to hook CO2 sensor that is UART, please advise what port can i use for that?
RE: PZEM-004T With A6 on Serial - admin - 09-13-2024
if your CO2 sensor is serial signal by TTL level. you can use a RS232->TTL converor module. so that you can use RS232 port.
