KC868 Outputs not working - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: KC868 Outputs not working (/showthread.php?tid=6610) |
KC868 Outputs not working - blazej.k - 09-05-2024 It seems that my outputs are not working (no leds, no voltage change). I measured the voltage on the optocuplers and its ~1.1 V beetween optoupler legs (as on image): I tride official firmware and esphome, both are responding to commands (on = 1.1V, off = 0.0V) RE: KC868 Outputs not working - admin - 09-05-2024 take a photo how you wire your KC868-A16 board, i think you have not connect green terminal of Vin with DC12V. RE: KC868 Outputs not working - blazej.k - 09-08-2024 Wiring was kind of ok. The wire supplying power to output part was faulty, it seem to have almost no resistance when out of circuit, but broken in the middle. That is first time when new electrical wire (stranded) was broken. Thanks for the tip. RE: KC868 Outputs not working - admin - 09-09-2024 ok |
