KC868-A32 wiring - Printable Version
+--- Thread: KC868-A32 wiring (/showthread.php?tid=6613)
KC868-A32 wiring - ragaimeena - 09-06-2024
Hi
I am interested in KC868-A32 to use as a central module with some assistant
I am trying to:
1-control multiple 24V DC LEDs
2-Control an irrigation system
3-connect door/window sensors, motion sensors and other sensors
questions:
1- can this be achieved with one A32 board?
2- wiring the LED (24V DC) to the relay output, I need help with. I will use Mean Well 24V DIN rail mounted power source for the LEDs
3- can I run the irrigation system on the same board? can you give me some direction on this if possible
I will be sing ESPhome
Thank you
RE: KC868-A32 wiring - admin - 09-06-2024
1. it's OK, just you need calculate the relay channel number you wanted.
2. relay control DC24V load is ok.
3. i don't know your "irrigation " details. if only use for ON/OFF switch, it's ok.
RE: KC868-A32 wiring - ragaimeena - 09-06-2024
(09-06-2024, 10:58 AM)admin Wrote: 1. it's OK, just you need calculate the relay channel number you wanted.
thank you for your response
the irrigation is similar to this
https://community.home-assistant.io/t/diy-8-station-irrigation-based-on-esphome-on-kc868-a8-relay-board/459599
 but want everything to be done with A32  ( use 8 relays for the irrigation 1-8/// use 24 relays for LED light)
is that OK
do you have any comment on this YAML in the link?
is that OK
Thanks for response
Irrigation is similar to this
I want to use relays 1-8 for irrigation
Relays 9-32 for LED lights
Do you have any comment on the YAML in this example?
Ultimate goal is to have everything run with one board
Also can A-64 be used or the relays will not be appropriate since they are MOSFET?
Thank you
thank you. I am trying to post a reply but not allowing mr
I am trying to use an example for irrigation I found on home assistant forum (tried to paste the link but not allowed)
I want relay 1-8 to control the irrigation
relay 9-32 to control LEDs
can I also use A-64 or the relay MSFET will not be enough?
Thank you
here is yaml file for KC868-A8: https://www.kincony.com/forum/showthread.php?tid=2367
if use KC868-A64, you can add KC868-E16v2 extend relay module.
