A16 crashing when using string driver - Printable Version
+--- Thread: A16 crashing when using string driver (/showthread.php?tid=6636)
A16 crashing when using string driver - brendon - 09-09-2024
Hi there,
I am writing a TCP string driver for our AV system and I have the board going, and the inputs/outputs work, I am getting feedback.
However, if i send commands quickly it seems to be able to easily overwhelm the board and it crashes - it will reset and work again after a short while.
I'd understand if it was a lot of packets, but I'm literally sending 1 a second and that's enough to crash the board - it should be able to handle this faster than I can click without issues?
I am only sending one string at a time, either all on, all off, or a multi-on which does a bitwise operation on the AV side and sends the correct string.
Can you advise why this is?
Thanks
RE: A16 crashing when using string driver - admin - 09-09-2024
what KCS firmware verison you are using?
what command list you have sent?
if you can take a video, we can test as your steps.
RE: A16 crashing when using string driver - brendon - 09-22-2024
Sorry, I missed this reply.
I have fixed the issue by doing ordered commands on the tcp driver. I would imagine the same would work with the string driver (ie waiting for the code to return its feedback before processing new code).
Thanks for the very fast reply!
RE: A16 crashing when using string driver - admin - 09-22-2024
ok, good.
