ESPHOME DAC 0-10 Valve control - Printable Version
+--- Forum: KC868-A4S (https://www.kincony.com/forum/forumdisplay.php?fid=41)
+--- Thread: ESPHOME DAC 0-10 Valve control (/showthread.php?tid=6648)
ESPHOME DAC 0-10 Valve control - montemartello - 09-09-2024
I would like to make a PID control of 2 3-way valves of the HVAC system. The valves have a 0-10V control and are powered by 24VAC.
I saw the example that controls an RGB led, but now ESPHOME has added the "valve" entity. Is it possible to have an example of how to control a 0-10V valve?
https://esphome.io/components/valve/index.html
Thanks
RE: ESPHOME DAC 0-10 Valve control - admin - 09-09-2024
just use your valve as a dimmer in ESPHome. so can change the speed.
RE: ESPHOME DAC 0-10 Valve control - montemartello - 12-24-2024
I didn't like managing valves as if they were lights, I also had difficulty using the output on automations.
So I rewrote the code as "number" in %.
See if it can be useful to others.
  friendly_name: miscelazione
  on_boot:
    priority: -10
    then:
    - output.set_level:
        level: 1.0  # 100%
    - output.set_level:
        level: 0.7  # 70%
substitutions:
# Actions to set initial DAC values on boot
esp32:
  board: esp32dev
  framework:
    type: arduino
  encryption:
    key: "xyxyxyxyyxy"
ota:
  platform: esphome
  password: "xyxyyxyxyxy4b"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Miscelazione Fallback Hotspot"
    password: "xyxyxyxyyxyx"
captive_portal:
# Web server for diagnostics
web_server:
  port: 80
# Sync time with Home Assistant
time:
  - platform: homeassistant
  - platform: uptime
  - platform: wifi_signal
    name: ${name} WiFi Signal
    update_interval: 60s
    device_class: signal_strength
    unit_of_measurement: dB
output:
  - platform: esp32_dac
    pin: GPIO25
    pin: GPIO26
# Define custom components to represent the valves
number:
  - platform: template
    name: "Valvola Miscelatrice 1"
    min_value: 0.0
    max_value: 100.0
    step: 1.0
    unit_of_measurement: '%'
    icon: "mdi:valve"
    optimistic: true
    set_action:
      then:
        - output.set_level:
            level: !lambda "return x / 100.0;"
    initial_value: 100.0
    name: "Valvola Miscelatrice 2"
    min_value: 0.0
    max_value: 100.0
    step: 1.0
    icon: "mdi:valve"
    optimistic: true
    set_action:
      then:
        - output.set_level:
    initial_value: 70.0
    pin: GPIO02
    name: "Pompa Piano 1"
    icon: "mdi:pump"
    pin: GPIO15
    name: "Pompa Piano 2"
    icon: "mdi:pump"
