4-20mah sensor wiring example - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AIO (https://www.kincony.com/forum/forumdisplay.php?fid=46) +--- Thread: 4-20mah sensor wiring example (/showthread.php?tid=6707) |
4-20mah sensor wiring example - aucirc - 09-16-2024 I'm considering the KC868-AIO - I need several water level sensors and interested in using the 4-20mah version of this (as the accuracy is better over longer distances) https://aliexpress.com/item/1005006338737673.html It's a two-wire sensor, but I can't find any examples of how this should be connected to the KC868-AIO? As these work best with 24V should the KC868-AIO be powered with 24V also? RE: 4-20mah sensor wiring example - admin - 09-16-2024 KC868-AIO analog input port support 4-20mA sensor. KC868-AIO support use by DC24v power supply. just let sensor and dc24v power supply series connection with KC868-AIO's analog input port. RE: 4-20mah sensor wiring example - aucirc - 09-16-2024 (09-16-2024, 01:34 PM)admin Wrote: KC868-AIO analog input port support 4-20mA sensor. KC868-AIO support use by DC24v power supply. Thanks - just to confirm, like this? cd74hc4067 Any advice for how to set this up in ESPHome? The YAML template seems to be configured to measure voltage for all analog inputs? https://www.kincony.com/forum/showthread.php?tid=2736 https://www.kincony.com/forum/attachment.php?aid=2189 RE: 4-20mah sensor wiring example - admin - 09-16-2024 diagram correct. here have video tour for how to use 4-20mA sensor in home assistant by ESPHome: https://www.kincony.com/forum/showthread.php?tid=3499 it's the same way for KC868-AIO, just modify the analog input in yaml file. |
